Cardsin2005
- Aug 4, 2014
- 38
- 36
- 2014
- 5.7 Hemi
I just finished my system so I figured it is time to share. My old truck was wrecked last summer and the subs and 4 channel amp from that setup
were saved and put in my new truck. Everything else is new except for the EQ and Crossover, I purchased them used form a local seller.
Here is the run down:
Pioneer AVH-4000NEX
Kenwood EXcelon XR-4 (3in Dash Drivers and Tweeters)
Powerbass ACA-480 (6.5in Mid bass drivers in doors)
CT Sounds 1400.1 (4 12in subs behind seat)
JBL GTE-422 (22/11 Band Equalizer)
JBL GTX 47 (7 Channel active crossover)
Dayton Audio AMT Mini-8 Air Motion Transformer Tweeter
Dayton Audio RS75-4 3" Reference Full-Range Driver
Rockford Fosgate Punch Pro 6.5" 4-Ohm Midrange
Kenwood KFC-W3012
My goal for this install was to build a very clean looking SQ system that would fit 4 12s in a regular cab truck without doing a blow through. I
knew I wanted to run a 3 way active setup from the start so finding room for all the amps was the first step.
Here we are running the power wires and RCAs. There is (1) 0 gauge power wire from the battery to the sub amp and (1) 4 gauge power wire to power
the front stage amps.
Under the hood I have 2 fuse holders. One 0 gauge and one 4 gauge. I wanted it to look stock so all wires are loomed and wrapped in black
electrical tape.
That is the factory battery bracket. The stud was pressed out and a longer bolt was put in it's place so we could get the ring terminals on it. I
like to keep it nice and factory looking.
The front stage is powered by a 4ch Kenwood - KAC-X4R and a 2ch Powerbass ACA-480. Luckily there is a lot of room under the seats in this truck so
I was able to fit the amps in with little effort.
Next came the front stage. For the low end I used Rockford Fosgate Punch Pro 6.5" 4-Ohm Midrange Drivers in the doors. Some how I forgot to take
pictures of that install.
In the factory location for the 3in drivers I used Dayton Audio RS75-4 3" Reference Full-Range Driver
I wanted some better power handling and punch out of the 3in drivers so I 3D printed some enclosures for them that drop right in to the factory
location. I added some polyfill in the pod with them and they sound unbelievable for $22 drivers.
For the tweeters I wanted to try something a bit different. So I went for Dayton Audio AMT Mini-8 Air Motion Transformer Tweeter. I can not say
enough about the amazing quality of these tiny tweeters. They are way louder then they need to be, this allows me to have a lot of headroom. These
tweeters are so smooth, there is no sibilance at all. They sound very natural and can be as sharp as you want them to be. Since they play up to
40,000hz they add one more layer to the sound. I know humans can't hear that high but the sparkle they add is amazing.
Pioneer AVH-4000NEX
Kenwood KFC-W3012
electrical tape.
