4",5" or 6" lift with 33.5 tires
Tarrelld
i have 2010 dodge ram that i want to put a suspension lift on, im trying to determine how high i want to go. i currently have 33.5 with stock rims. i keep hearing that most people like 35 but i understand that you loose mileage and power. if i stick with my 33.5 with a 6" lift will it still look good and am i going to have the same issues with my current height tire with mileage and power?
harrison725
Atl, Georgia
Is your truck a 2wd or 4x4? because that will make a big difference in the actual lift height
Johnn123
Ontario
Lifting will cost you mileage regardless what you do for tires. Period.
With a 33.5" tire a level would probably be all I'd do. 35's on a 6" look small if you ask me. Just right on a 4". 33.5" on a 6" will look weird IMO. This is if youre a 4x4.
You could regear to a lower ratio to regain lost power and mileage with a bigger tire size.
blackbeautyhemi
Lewistown, PA
If you only wanna run a 33 and worried about gas mileage then why don't you just put a leveling kit on it?
Worrying about gas mileage and lifting a truck don't go hand in hand lol
harrison725
Atl, Georgia
If you do happen to have a 2wd, I have a brand new set of 3" and 4" lift spindles Im wanting to sell. Dm me if your interested
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Fully agree with the guys above. If you want to keep the 33.5" tires I'd stick with a level. They'll already be borderline small on that setup IMO. Any more lift than that and they'll definitely look too small.
ChloeBrooks
