4.7 l bucking
deuceram
south jersey
4.7 v8
so my 4.7 l 2wd ram decided to hang rpms up very slightly and then bucked and stalled im not quite sure what this problem could be if anybody could help itd be greatly appreciated this all happened when motor was not warmed up it didnt do it when warmed up it happened a few times too
bigbadram1500
Springfield, IL
hmm, the time my 05 4.7 did that, the egr valve was bad. For starters, I'd check to see if the truck is throwing any codes.
The Assassin
B-more careful, Murderland
When's the last time you did a basic tune up on it? Might want to check out on here about Sea Foam. It does a heck of a job as far as cleaning out the fuel system.
KeysRam
Islamorada,Florida
4.7 Magnum
any codes or check engine lights come on mine did it because i had a lose hose on my EVAP
deuceram
deuceram
south jersey
4.7 v8
yeah i scanned that and my trans too and no luck so i guess ill just wait for somethin to throw a code
rlmuirheid
Cincinnati
4.7 Gas
Mine did the same thing. Had injectors cleaned and problem went away
