4" Zone lift with Fox 2.0 coilovers and shocks
ChaseH878
Virginia Beach
Good Day All,
I have a 2015 1500 4x4 and I am wanting to put a 4 inch lift on it. I'm pretty set on the 4" inch Zone kit and would like to add the Fox 2.0 performance series coil overs and shocks but I notice that they will only work for a 0-2" lift. Any advice on how to achieve this setup would be greatly appreciated.
RJL1
Jersey Shore-By the beach
Welcome to the forum.
There's TONS of talk about this exact topic. I was set on getting a 4" system as well but went with the Zone 6" with the front set at 5" and rear 3" springs. Fox 2.5 coil overs in front and Fox 2.0's in the rear. Also the Zone UCA's.
I researched this relentlessly and this was the system that worked for me. My truck drives like a dream and looks fantastic.
I suggest you take a few days and do some research here. This forum is a fantastic resource with tons of outstanding members that are very helpful.
crazykid1994
The 4” lift with the fox 2.0 will be fine. The reason it says for 2” lift is because the coilover lifts you 2”. It can be used with the lift. You will still need to use the front 4” strut spacer included in the kit but you will then have 6” of lift in the front.
atreides
USA
Would using the 2.0s with a Zone 6'' lift require setting the coilovers to 2'' of lift and adding the 4'' strut spacer on top? So the 2'' preload spacer from the Zone kit isn't necessary at all?
crazykid1994
Correct. And actually it’s a 5” strut spacer and 1” preload I think. So you would actually be at 7” lift
Nick@GotExhaust
Supporting Vendor
SC
@RJL1 So can the 6" inch kit with the coilovers put the front at only 5" or can it go down to 4"?
so without the preload spacer and running the 2.0 coil overs at the lower setting you would be at 5", you can adjust them up to 7" of lift. so anywhere between 5" to 7"
No issues running Foix 2.0 coil overs with the Zone lift. We have lots of customers running that exact set up and love it.
ChloeBrooks
