44 inch project
Dadi
Iceland
5.9 cummins
I finally decided to build a truck the way I want it:
Diesel
Strong mechanically
44 inch tires with minimal lift
Here is the progress
First the car
2005 Ram 3500 super duty, 5.9 cummins with 110 k kilometers on the clock
Then 4 inch lift
Dadi
Dadi
Iceland
5.9 cummins
Here in Iceland we are required to have flares that cover the tire. I decided to use flared fenders and widen them on the inside of the headlights. This means moving the headlights out by about 4 inches.
20190509_172932.jpg 20190512_140020.jpg 20190515_210828.jpg 20190619_222604.jpg
buddy guy
alberta
wow!!!! welcome to the forum. that is a hell of a project! hats off to you and keep the pics coming! we do love them pics!
Dadi
Dadi
Iceland
5.9 cummins
Thank you for positive feedback.
Here is a picture of the rims after widening and beadlock. These are the original 17" steel rims that came with the truck.
Elevated 2013
Huntley, IL
Nice looking project! Can't wait to see how that looks in the end! Did I miss where you changed the rear axle to single rear wheel as opposed to the dual rear wheel axle that was on it at the beginning??
Dadi
Dadi
Iceland
5.9 cummins
Thanks. No axle change needed. The tires are as wide as the dual ones. Ony need a spacer.
buddy guy
alberta
if you don't mind me asking, cause I come from Alberta where we have huge earthmovers with those big tires that cost 100,000 per tire, how much those tires each cost? i find it fascinating how the bigger the piece of rubber, the price jumps way out of proportion with the increase in size! i'm guessing 500-600 bucks canadian a tire?
Dadi
Dadi
Iceland
5.9 cummins
Good question. These are Nokian radial tires that were developed for Arctic truck. The price is an eyewatering USD 1900 each. However, they cannot be compared to diagonals in terms of road manners.
buddy guy
alberta
i bet! 1900 each. guh....like i said, out of proportion with amount of rubber, commercial application allows them to charge so much. everytime i see an oversize semi with a load of big earthmover tired on it, it's like 10 of them. 1 million bucks worth of rubber right there heading to alberta oil sands.
buddy guy
alberta
i find your whole build fascinating! mind if i ask what you do for work?
LeesEvoX
Houston, TX
Hemi 6.4l
LOL those tires look MASSIVE up front,but then tuck in really nice under the dually bed hahaha.
Awesome fab work on the fenders, and yes. Sid is THE perfect name for that truck hahah
