46RH trans help with numbers
firsttimer
5.2l
I have a 94 ram 1500 4x4 with a good 5.2l and a bad 46RH the number stamped into the housing just above the trans pan is PK52118325 2018 8121. I found a tranny that looks same as mine but the number is PK52118329 2050 5482. I called dealer and they said they could not give me any info from those part numbers. Is there anywhere I can go to find out what trans the later is. Thank you.. If I posted this in the wrong forum please forgive me. thank you
Merc225hp
NA
truck
gas
Welcome to RF
Here you go hope it helps.
Part number 52118329 46RH
TRANSMISSION ASSEMBLY, Complete w/Overdrive Assy., 4-Speed Automatic, 46RH, TRANSMISSION ASSEMBLY, Complete w/Overdrive Assy., 4-Speed Automatic, A500. 46RH, w/5.9L Eng. w/Electronic T/Converter Lock-Up, After 10-18-93, 46RH, w/5.9L Eng. w/Electronic T/Converter Lock-Up, Up To 10-18-93, 46RH, w/5.9L Eng. w/Electronic T/Converter Lock-Up, w/P.T.O., Up To 10-18-93, A518, w/5.9L Eng. w/Electronic T/Converter Lock-Up, 1993, Up To 10-1-1992, A518, w/5.9L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992. .
Stock Code R2118329AB ; 04762706; 04762706AB; 52118183; 52118306; 52118329; 52118722; 52118739; 52119173; 52119173AB; R2118329AA
Part number 52118325 46RH
TRANSMISSION ASSEMBLY, Complete w/Overdrive Assy., 4-Speed Automatic, 46RH, TRANSMISSION ASSEMBLY, Complete w/Overdrive Assy., 4-Speed Automatic, A500. 46RH, w/5.2L Eng. w/Electronic T/Converter Lock-Up, After 10-18-93, 46RH, w/5.2L Eng. w/Electronic T/Converter Lock-Up, Up To 10-18-93, 46RH, w/5.2L Eng. w/Electronic T/Converter Lock-Up, w/P.T.O., After 10-18-93, 46RH, w/5.2L Eng. w/Electronic T/Converter Lock-Up, w/P.T.O., Up To 10-18-93, A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, 1992, A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, 1993, Up To 10-1-1992, A518, w/5.2L Eng. w/Electronic T/Converter Lock-Up, After 10-1-1992. .
Stock Code R2118325AB ; 04762707; 04762707AB; 52118185; 52118308; 52118325; 52118735; 52119170; 52119170AB; 53008147; R2118325AA
F
firsttimer
5.2l
thank you. That is a big help. so this will bolt right in. now from what I understand is I will need to use a torq converter from the 5.2l. I also seen in some other post about removing the weights from the 5.9 tq and using it in the 5.2l.. any truth to that.
NYCruiser
Yonkers, NY
I think the weights are what is balancing it rotationally. I don't think removing them would be a good idea.
Merc225hp
NA
truck
gas
The flex plate is what weighted not the tq converter.
In the photo below you can see the weight, this is for the 5.9, the 5.2 has no weights on it.
F
firsttimer
5.2l
thank you again you have been a big help. I just got back from picking up the unit. Overall it looks pretty good. no leaks fluid smells good. I got the tranny, overdrive and transfer case and a extra front drive line. Im going to pull the old tranny and install this one on Saturday. looks like it shouldn't take more than a few hours.
Merc225hp
NA
truck
gas
More like an 8 hr job but give'r heck. Don't forget to flush the tranny lines and the coolers don't want any junk getting into the new/used tranny.
Mind me asking what you paid for all of your parts? Nice score by the way lots of extra parts to keep on hand.
Silver Tex
Welcome to RF
Hi Merc,
I cannot find information on the following part number on my transmission.
4 PH52119623AA 1599 1596 (pulled from the just above the pan, drivers side)
I was hoping you could tell me that this is a 46RE as I have already ordered and am about to receive the new tranny, which is a 46RE.
Thanks,
Scott.
leadrofthepak
Shelton, CT
I didn't think the put the RH is any Rams (I could be wrong). I was under the impression all 1500 Rams were equipped with the 46RE.
Silver Tex
Thanks guys. I had understood that as well and was looking for some confirmation.
Merc225hp
NA
truck
gas
Hi Merc,
Thanks,
Scott.
That part number is not working for me at all.
You do have a 46re so you did order the right one.
Silver Tex
Thanks Merc,
We have a similar problem. The part number doesn't work for you and the existing part doesn't work for me :) Just about to have that resolved however thanks to all the fine folks on this site.
Thanks All & have a very Merry Christmas!
2NDGENGASSER
360 Magnum
more like an 8 hr job but give'r heck. Don't forget to flush the tranny lines and the coolers don't want any junk getting into the new/used tranny.
i went with new dorman lines and the biggest hayden trans cooler that my store had in stock. Pulling the old 46re was a breeze as ive had it out once before, going back in with a different one was a bit tricky as i was a lot more carful :p take your time.
