Many thanks for the info/suggestions, Guys! Soooooo I pulled the trigger and the parts are in transit right now... I made a few last minute modifications and ordered the 4" SST with the rear 5100 Bilsteins, along with two additional 5100 Bilsteins for the front, just to match shocks all around. I also last-minute decided to order 295/65R20s instead of 285/65R20s (KO2s) for the extra height and width...I know, more noise, weight, lower MPG but I figured it was the best balance of function/aesthetics (I may well be proven wrong).
I was feeling fairly good about my purchase until (3) new things have donned on me:
1. These are 35" tires on a truck with a 3.21 gear ratio. Hadn't really read too much about regearing until after the purchase. Would you guys recommend regearing if I'm not off-roading? I'd hate to add more cost to the build, but for the sake of the transmission, MPG, and the ride, I'd do it if it's recommended. I've heard 4.56 and 4.88 mentioned on the forums ( and here: https://www.tacomaworld.com/tirecalc?tires=275-60r20-295-65r20 ), and a lot of guys say it's the best mod/update they've done. If recommended - should I get it done now, when the truck is already on the hoist, or would you recommend I experience the lift/tires at 3.21 for a few months and then upgrade in the spring? ( I won't exactly be ripping around at high speeds in the snow, I'd expect ).
2. My truck will likely be rolling out of the shop into salt-slush roads
Should I be protecting the new Fuel Militia (matte black) wheels with anything before it leaves the garage? Would like to be able to clean/polish them up in the spring and have them looking like new. ( I could save my new wheels/tires for spring and put winter tires on my stock wheels, but now I'd have to buy new tires for the snow, which was the whole reason I started this build anyway...)
3. I have my truck Krown'd every year for rust-protection, and just had it done. I was going to take it back into the Krown shop after the mods to get them protected before too much salt exposure. Recommended? Will they coat the Bilsteins and if so, will that affect their function in any way?
Thanks in advance for all your help - point of no return
@Patola Must be a different Yak - I'm an Oilers/Sens fan
