4th Gen Window lockout switch
jfurry
california
The window lockout button on my 2013 1500 Longhorn crew cab works on the rear windows but not the passenger window. Has anyone had a similar issue or suggestions for fixing? Thanks in advance for your replies.
jawzs2
Air Force
South Jersey
Normal operation - from page 48 in my 2014's owners manual
Window LOCKOUT Switch (4–Door Models Only)
The window LOCKOUT switch on the driver’s door
allows you to disable the window control on the rear
passenger doors. To disable the window controls on the
rear passenger doors, press the window LOCK button
into the latched or down position. To enable the window
controls, press the window LOCK button again and
return the switch to the released or up position
audiophile
5.7L
Yeah, as jawz has stated, it is not meant to lock out the front passenger window. Only the rears.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I think I asked this question before and I think that the option can be configured in AlfaOBD BUT it won't work on 2014 and below because the option is not present in the door module.
Mmmcflurry
California
3.6L
Has anybody confirmed if it is possible to configure the front passenger window to lockout via AlfaOBD?
I'd like to know before dropping a couple hundred on an compatible OBD2 device and buying AlfaOBD.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
If you mean child lock out I think so but only certain years (maybe 2016+)
Marty424
