4x4 vs 4x2 lowering kits
purcell1
hemi
Does anyone know what the difference is between the two? Looking at a 2/4 for a 4x4 are hard to come by. Can’t a 2wd kit be used on a 4wd? Isn’t it just shocks and springs?
Thanks guys. Recommendations welcome
rojo_143
No they cannot be interchanged well at least the front anyways. The 2WD versions use a coil spring with a separate shock location where as the 4WD and a coil spring strut combination.
Ground Force and Belltech both make a 2/4 lowering kit for the 4X4's,and if you want to go really low there's Inez's kit.There's also an outfit building drop struts for the 4X4's,but I forget their name.
P
purcell1
hemi
Got chya, thanks!
rojo_143
There are a few different kits out there for us 4WD guys from Belltech, Ground Force and Inez Hot Rods. The Inez kit is a 4/6 kit but you should be able to adapt it to get a 2/4. On there kit they cut down the a standard 4 inch drop coil to achieve a 6 inch drop. I am sure you could get a set of Bilstiens or belltech street performance Struts up front and set them up a notch or two to get a 2 or 3 inch drop vice the 4.
DwnDak
Ontario, Canada
I went with GF 2" fronts and Belltech 4" rear's .... But I've seen Belltech recently put out a complete 2/4 kit... The Part #: 965SP .. I don't know if anyone here has installed it yet though.
I've had no issue with my current 2/4 setup but I'm going to (I keep saying this) grab some lift/lower struts and machine a drop groove of an inch in them so I have a 3/4. I think that'll be sitting right, if I don't skip it all for a 19 Limited in the spring. Couple months to wait yet.
jeffawats
thompsontown pa
I talked to the guys at suspensionsuperstore.com and they told me the adjustable front lowering strut is in production for the 4wd.
DwnDak
Ontario, Canada
Thats interesting.. They've been out for GM guys for a while, but the Dodge options are only 0" - 2" lift only. Did they give you any timeline at all?
jeffawats
thompsontown pa
been about a month and they had told about 90 days till release.I just checked the site yesterday and nothing yet
jeffawats
thompsontown pa
I just messaged them and Rob says his guess would be 60-90 days and price would be in the $89 each range
Dobaramguy84
Tonwanda, n.y
that kit from belltech shouldn't matter if its a qc or rc correct? or is there an actual difference?
dracman
canada
2017 black out edition
what company has the front lowering struts for 4x4.
thanks dave
Orca
