5.7 Rear Main Seal Replacement
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
Ok guys I have searched everywhere. Is there a write up on changing the rear main seal in a 09’+ 5.7 4x4?
I have a steady leak coming from the trans inspection plate that is dripping on my driveway. I think it may be rear main seal.
1- Can I do this myself?
2- Do I have to drop the trans?
2- Anything else I should check while doing this?
Hemi395
Cape Cod MA
Interested as well, pretty sure mine is leaking...
46RamMan
U.S. Navy Veteran
Missouri
You have to pull the trans and transfer case and flywheel flex plate. The seal is a one piece round seal that comes off the back of the crankshaft. It is a very difficult job if you have never done one before..
