6.1L will physically bolt in, you'd need an '05 pcm swap to even run it though since the '03 is the ******* step child hemi. The 6.4L would not work as it's a VVT engine and the '03 wouldn't even work with it. Now, if you swapped everything and had a custom harness made then sure, you could get it to work but it'd be a whole lot cheaper just stroking out a pre-'09 5.7L block or installing the 6.1L.
