5.7L Water Pump Inlet Tube
Livinalittle
Ontario
2013 Sport, 6 speed, 4x4, 3.92
Does anyone know where I can order JUST the inlet/outlet tubes without having to order the entire pump? Everywhere I look it’s a full assembly.
The tube isn’t leaking yet but it’s not far off. Truck only has 120 000km on it so I’m not worried about the water pump yet.
jws123
nj
if tube is rotting out that means it probably is time to replace the pump they are not expensive takes a little time to replace but not to bad. also the chances if you getting the old tube out are low.
Livinalittle
Livinalittle
Ontario
Thanks guys. I kinda figured that would be the answer lol. Might as well do the thermostat while I’m at it.
