5.9 to 5.2 tranny swap
Janamb
I have a 99 ram that motor is shot and a 99 Durango with a 5.2 that needs tranny can I put the tranny out of the 5.9 into the Durango both are 4 x 4?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Yes you can, just use the flex plate from the 5.2 engine. Everything is a direct swap.
J
Janamb
Thank you then I will installing it tomorrow
J
Janamb
It doesn't mount up the same on left side of tranny around heel housing where linkage is
dudeman2009
Magnum 360
You might have to fight with it a little bit. I swapped my transmission from my old blown up 5.2 to my newer 5.9. I did it all out of the vehicle and it was a bit of a pain to get it all to line up on the ground. If you're doing it inside the engine bay, you're going to have to fight with it a little bit.
