5-channel amp on stock radio?
RAM LI
I have Alpine PDX-5 amplifier that I am trying to hook up to my stock radio. It is a five channel amp. The amp has three different inputs. I can't figure out the best way to hook this up to the radio without replacing the HU.I know PAC audio makes a couple different pieces to use but not sure which. Any help would be appreciated thanks
Designflaw
Lex. Ky.
2013 CC Sport 4x4
Buy a Signal processor
Sent from my DROID RAZR HD using Tapatalk 4 Beta
Marc1982443
Southern Maryland
2012 big horn cc
Depends. The JL amp I have can accept 2 inputs but play all 5 channels. Does the alpine do that also? You just need a line converter really.
Sent from my iPhone using Tapatalk 2
badblackram06
MS
Yeah that amp is a 4 channel (75w x4) with a mono (300wx1) channel. What sub/speakers are you running? Usually on a stock radio you'll need one of those speaker wire to RCA cable converters and maybe some splitters to run 2 sets of RCA cables to the amp to power a sub and the door speakers.
R
RAM LI
Running 4- JLB GTO938 in the doors and a 10" kicker. They are all out of my old truck but I had an aftermarket head unit in that. I was thinking of using one of the line output converters but was not sure if using all those splitters would be a good idea
badblackram06
MS
The splitters work great. I've used them and there is NO noticeable difference in sound quality.
kkreit01
Olathe, KS
It depends on "WHICH" stock radio? If it's an Alpine (OE-amped) system, you'll need an input summing device/or costly processor (LC6I and above). The PAC device will also work, but you lose all control of your sound (no bass/treble, etc.). If you have the base OE radio (w/o amp), you can get buy with a cheap LOC, and use RCA splitters if the amp requires all inputs.
mvm2
