5500k halogen
RamNight18
atlanta
Has anyone tried a 5500k halogen bulb in the highs? I want to find one that matches 5500k hid lows
Ram Night
Southwest, Michigan
I have never seen or heard about a halogen bulb that is 5500K. I find these hard to work as a halogen is around 2700k.
I installed Supernova V3 leds on my high heams just for the color match to my 5500K hid low beams.
homeguy
Calgary AB
2013 Big Horn
How did the V3 LED light work out?
Ram Night
Southwest, Michigan
I had the high beams selected so the low beam shutter it in the high beam position.
Ram Night
Southwest, Michigan
Next, install a set of KC Highliter led off road lights behind the grill for a lot of lighting at night.
RamNight18
RamNight18
atlanta
RamNight18
RamNight18
atlanta
Any modifications needed to fit the supernovas into housing? Thanks
WhiteNBlackRam
Southern California
I ran the led supernova v.3 (currently up for sale) for my low beams and fogs. Easiest kit, plug directly into the factory plug and you can hide all the wires inside of the housing.
RamNight18
RamNight18
atlanta
So they don’t require a extra canbus module?
Ram Night
Southwest, Michigan
None at all. Turn them in loke the stock bulb, and plug them on. The only thing I did was put a piece of trim molding tape on the anti flicker module, and stick it on the housind so secure it.
