Zackary Wilkinson
Anyone know if the 5th gen center console will bolt up in place of the 4th gens? really like the extra room that the new center consoles have and would do the swap if anyone has some input on if it will work or not.
Any chance you can find the link?There’s a thread in member trucks area. He did it. I don’t think it’s bolt direct fit. Required a little work. The build I’m referencing basically put a 5th gen interior in his 4th gen.
Did you try wiring the usb ports up so they’d work with your head unit? I’m trying to on mine but they won’t support CarPlay. Don’t k ow if I’m doing something wrong or it’s a bad media port or whatWorks...
Had to take out vent pipe underneath console
Had to trim bottom on both sides for hump on floor
Used a switched 12v and ground wire to splice in the usb ports.
Not bolted in yet.
But I'm happy so far
Need those side pieces like 3rd pic has in his.
View attachment 480820View attachment 480821View attachment 480822
Works...
Not bolted in yet.
Following, did you get any feedback on this.I'm looking to do the swap from 40/20/40 in a 2016 3500. Do I need the radio bezel from a console truck? What about brackets? Would the brackets from the 5th gen work? Or do I need 4th gen brackets out of a console HD truck?
did you ever get the trim piece the the front to work??Works...
Not bolted in yet.
I was able to get Android Auto to work on my swap, but only from the 2 usb's on the right. I'll pull everything apart tomorrow to look at my pinouts.I know this is an old thread but I have a 2020 center console and I plan on putting it in my 2012 ram. Anyone get the usb ports to work?
Do i need the rewire any wires for the 5th gen console to work?I was able to get Android Auto to work on my swap, but only from the 2 usb's on the right. I'll pull everything apart tomorrow to look at my pinouts.
What did you use to mount it to the floor? 4th gen brackets or the 5th gen brackets or did you make your own? I have the interior of a 2020 to put in my 2016. Doing the same thing.Works...
Not bolted in yet.
