5th Wheel Hitch
Fulltilt
North Cowichan British Columbia
6.7 HO Cummins
Hi guys
I have a Pullrite model #4400 auto slider which I have carried over to our new Dodge Ram 3500 LTD. The Ram has the "hitch prep", & I have had conversations with PullRite, their customer service tells me the hitch will install, using their adapter#4439. Have any members used this adapter with this series of hitch?
2003F350
6.7 CTD
I'm guessing that if you go to their website and look up that adapter part number, you'll find that it's probably an adapter that will attach to the bottom of your existing hitch setup (in place of the legs/rails you currently have) and then drop into the puck system installed in the truck.
If you have any concerns or are looking for any particular bit of information, it would probably be helpful to post it up - you'll get more responses to a targeted question than an open-ended one.
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
etrailer.com has great customer service & usually gets back to you within 24 hours. Probably can get the adapter through them as well.
