5th wheel towing when lowered
dhuf
New Tripoli, PA
6.7 L Cummins
Does anyone know if it is ok to tow a 5th wheel with the air suspension lowered. My 5w rides somewhat nose up but I can't lower the hitch between my 7" rail clearance. Dropping the rear a couple of inches would help level things out. If I can't, I guess I'll have to alter the suspension in the RV to lift it up instead. Thanks in advance!
diymirage
Banned
I think regardless of ride height it is imperative to have your towball be at the right height for the trailer
This may mean you need to buy a drawbar for you specific combination
OC455
Central NY
5th wheel hitch...
OC455
Central NY
I've got the same, you look at mine hitched up and it looks nose high a bit, but I'm also low as I can go on the 5th wheel hitch height as it can go. I don't know if you have any adjustment in the pin box height...
D
dhuf
New Tripoli, PA
6.7 L Cummins
Certainly don't want to go any higher on the hitch. My clearance to the rails is between 6 and 7 inches. I really don't want that any lower or we'll risk hitting. Can't adjust the kingpin.
Riding nose up angles the RV so if we use the receiver in the rear of the RV, it makes that lower to the ground. We had an issue with kayaks in a vertical rack.
I would consider driving with the air suspension in "alt height" but I don't want to damage the truck which auto levels itself when I hitch up.
nlambert182
Huntsville, AL
6" is fairly typical and what most would shoot for, but if you're careful and mindful you can drop down to 5" and be ok most of the time. It would help to have pics of everything.
So your pinbox is already adjusted all the way to the top?
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Alot of people use the Alt Height feature for towing.
Ram mentioned it used for Trailer towing in the feature video below.
Goto 1:22 time mark for 2500/3500 explanation.
D
dhuf
New Tripoli, PA
6.7 L Cummins
Thanks for the video. Not 100% sure it means it works when towing though.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Do a Google search. Plenty of responses in RV and other RAM forums of owners doing exactly what you want to do and is why Ram called it Alternative Height .
Jbinramona
Ramona
Cummins 6.7
2016 3500 dually, Cummins 6.7 HO, Aisin tranny. Jayco Seismic 4013 toyhauler. 33,000lbs scaled weight. I use the alt height setting. Been full timing for almost 3 years. Thats my experience, take it as such.
Stay safe, enjoy the trip!
