mowin
- Mar 1, 2014
- 462
- 152
- Location
- upstate ny
- 2017 3500 SRW
- 6.4 hemi
Just a thought if you are considering buying a new Ram. Maybe wait till the late 2015 production is out. Hoping we may get surprised by Ram on what is standard gearing and maybe even engine and computer mods??? 2014 was the first year that Ram had this 6 speed trans and also the first year for the 6.4 hemi in the truck. As for the dealers, very few in the dealership, at least here in the Rockies, have pulled much and none with the new engine and such, hoping that Ram will listen to it's 2014 customers for what can be improved. Truly, I believe that tweeking both computers would make quite a difference. Not that I would like to have terrible milage, but on anything over 1500 series, milage isn't even calculated. Loosing 1 or 2 mpg and being able to pull as a truck should to me would be preferable.As it is, the computer wont allow anything over 1/2 throttle in any gear but first. The engine is very powerful if given a chance. ie, pulling in low where more than 1/2 throttle can be given, pulls quite good even at low rpms. With the 3.73 gear, pulling on steep grades, 8% and up, can be an experience. If you are lucky, or "unlucky" enough to get to about 50 mph (will easily go that fast in 1st without over revving) and somehow get into 3rd gear, "Watch Out"!!! If you over accell. , it will downshift and NOT into second. It will hit first at about 6k. Believe me when I tell you, it will spin the rear wheels when it hooks up and that is with 13 plus k behind it. Will make your blood run cold. It only did that once and that was with only about 6 k on the truck and not broken in. It pulled so hard that it snapped some of the front body panel screws on the 5'er. Since putting in the 4.56, I don't have to run the high rpm's or push the truck to pull. Was worth, to me, every dime. Did have a few discussions with Ram concerning that. I do know that they listened at least as far up the chain as I could get. I did appreciate that.
I would like to know where you got the "as it is, the computer wont anything over 1/2 throttle in any gear but first" from?
and although i was going slightly uphill the whole stretch, i was at 2300-2400 rpm the whole time and it wouldnt shift out of 4th at all! At that point i tried letting it get to 5th and wouldnt...not sure whats up but i'll have to drive down the highway a few times this weekend
