68 RFE speed sensors stuck
samxware
Murrieta, CA
6.7 cummins
Hello! I recently got the code p0734, and i read somewhere here that changing the speed sensors could fix that problem. (truck is a 2012 2500 6.7 68rfe, 160k miles)
So, I'm trying to disconnect the speed sensors to change them, but I can't find the way to unplug them. I know i should just press the little release tab, but i pressed with all the force in my fingers and it didn't work. I even used a little wd-40 to try and loose it up a bit, but still I couldn't.
Do you have any tips on how to safely remove the sensors? I don't want to damage the connector under any circumstance. Also, is this common? I bought the truck recently, so i'm not really sure if anyone has ever serived the trans before. What do you think?
Thank you in advance!
-Sam
ameer73
