68228904AE/AH 2015 bcm capable of remote start
Thelegendl23
Just thought id let everyone know, everything I found said my 2015 had to have a new rf hub. In the title is the pn of my rf hub and it is indeed 2015. Yet, I ordered the key inlay, hood latch, harness kit and flashed it with obd and starts like a champ. So it must not be as simple as all 2015's need a rf hub as I see so many times again.. right? My rf hub is 68234884ac.
abbttb
Austin Tx
Can you share the individual part numbers you purchased to completethe remote start installation?
Sent from my SM-N950U using Tapatalk
Thelegendl23
Thelegendl23
68261143AA hood latch switch 2500/3500
68065018AA hood latch connector repair kit
Alpha obd
I ordered the key inlay on Amazon and just put it in my old key fob worked fine. I did not use a new rf hub or antennas.
abbttb
Austin Tx
Thanks for the part numbers, this will be my next mod.
Thelegendl23
Thelegendl23
Its a good one especially in Az, my rf hub is 68234884ac not sure if that also plays a role.
Thelegendl23
Thelegendl23
Why was this moved? It has nothing to do with the spot it was moved to. Its diy remote start and alpha obd which is also diy..
Arturo Rojas
