8.4 radio in 2009-2012 ram
daytonahemi08
HEMI 5.7
Newbie here! Has anyone did this? I'm looking to do it on my new ram 32ff322e4543638d47990d9959579f6f.jpg
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
Not to be a **** or anything, but there are probably about 10 posts asking the same question. The search button is your friend but the answer is no you can't.
D
daytonahemi08
HEMI 5.7
I searched and searched again couldn't find anything but thanks. I'm sure the Ac controls won't work but ima still try it
1500ram12
5.9L Cummins
Like I mentioned in another forum. Your going to need to compare the 2009-2012 wiring and the 2013+ to get the correct wiring going to the radio and then get the correct connector. They are completely different between the two. Even if you accomplish this there is no guarantee that the canbus system in the 2009-2012 will communicate with the radio. Although the radio is "thin" the mounting points are different and it appears the bezel is at least the same shape it maybe slightly different. Even if the 2013+ snaps into place you will run into the same issue as the radio.
That's a lot of time and money for something that most likely won't work.
If you want a big screen head unit look at alpine. You'll have to make a complete custom bezel but at least you'll know it'll work
Sent from my VS985 4G using Tapatalk
baum
savage, mn
2015 Laramie
the radio may work, but yes the ac cotrols will not.
if you want a large screen i would look into the alpine 8 or 9" aftermarket screens
D
daytonahemi08
HEMI 5.7
Well I work at a custom car audio shop so I'm sure I can make it happen. My speakers are powered by amps so all I need is for the radio to power on and send signal to my amp. If I get it to work I'll keep yall posted yes I've seen the alpine 9 inch I'd rather do a iPad install them that thing
CuylerTech
NH
6.7L
The radio requires specific CAN signals put out by the 2013+ rams for the radio to turn on. It does not simply just turn on when you apply power to it.
Etroze86
Grand Forks ND
Don't bother with it, wire a key on and use a tablet glassed into the dash, that shouldn't be to tough for a custom audio shop at all.
D
daytonahemi08
HEMI 5.7
Thanks looks like iPad install it is
southalum
