91 dodge d250 2wd 318
86 dodge
Midland city
Looking to lift my d250 wondering what all I needed to get for it. I’m wanting about 4 inches all the way around, as it sits right now it’s got a bit of a nosedive to it
u2slow
BC, Canada
Cummins 6BTA
I would see about a 2-3" body lift and an aftermarket steering shaft to allow it. Then look at a higher rate coil spring swap or a spacer (poly or aluminum).
Beware, the 1ton or diesel suspension uses a longer spring that won't fit the lighter suspension. It could probably be cut down, but the ride may be harsh. Ymmv.
