91 no crank no start
JustinB
Georgia
3.9 v6
Hey looking for any guidance with my 1991 d150 with a 3.9 v6 currently will not start just clicks when key is turned has power have replace ignition relay and the other relays located next to it new starter has been done can't think of what to check now turn key and clicks no crank no start just a click I've been chasing this issue for a week now and cannot figure it out a shop did some work for me and drove it out of the shop (until it started spraying gas from chewed lines) now it won't start ive checked all grounds going to the starter, motor, and firewall found 3 but don't know if I'm missing some (I probably am) just looking for some help hoping someone has had this same issue before me thank you
dusterdude
Hopewell va
Buy a remote starter button and hook it up and see if the starter will turn with it.if it does,turn on the key and crank it with the button and see if it starts.let us know how it goes
David Vandercook
Under the truck
Make sure your battery is doing at least 12.6 volts. If so, test the starter by bridging the solenoid with a screwdriver or something, if the engine does turn the solenoid is bad,if it doesn't turn over when you bridge the solenoid either you aren't getting power or the starter is bad. If that's the case use a multimeter to test the solenoid wires and make sure they have power when the key is turned. If they don't go down the wires and make sure no grounds and connections are bad. That's all there is the the starter system.
