97 Ram Help!
Aluminum
1997 Dodge Ram 2500
5.9L Magnum V8
First Problem Is My ABS And Brake Light Are On. I Don't Have An ABS Code Reader To Read The Code. Any Suggestions?
Second Problem My Check Engine Light Is On I Am Getting "P0754" Shift Solenoid A Electrical, What Do I Need To Check And Replace To Fix This? Or Do I Need To Replace The Solenoid?
Third Problem When I Put My Truck In 4Low The 4WD Shifter Shakes Horrible And Makes A Grinding Noise Under Neath The Truck. Any Suggestions?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
1: that is usually indicative of a failing master cylinder or the ABS sensor on the rear end.
2: I believe that is the code for the Governor Pressure solenoid in the transmission
3: You need to be stopped, transmission in neutral and SHOVE the t-case lever into 4LO in order for it to NOT grind. I learned this the hard way. lol
