99 dodge ram 1500 need advice on lift kit
Blucchese93
magnum 5.9
I have a 99 dodge ram ext cab short bed. I put a 2.5 skyjacker lift kit in. Which consists of an add a leaf and bigger coils. I would like to put coil spacers in and maybe lift shackles or bigger blocks in the back. So my question is if put another lift in will i need to get longer sway bar links or anything like that?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
On a side note, how do you like that kit? Did it level it or no?
B
Blucchese93
magnum 5.9
Yes i like the lift kit very simple. I put longer and better shocks on also and yes it sits very level
B
Blucchese93
magnum 5.9
Does any one have any advice that would help me out?
quadcab
360 Magnum
in order to gain more lift in the front you need to get new control arms I do believe. As for the rear get some add a aleafs or some lift springs. You could replace your block with a 3" but that is the most I would go with a block.
Sent from my SAMSUNG-SGH-I537 using Tapatalk now Free
B
Blucchese93
magnum 5.9
I already have a lift spring in the back. I dont know the size of the stock block. So if i get a 2in coil spacers would a 3in block make it sit level?
Arturo Rojas
