A bit of rough idle at a stop normal? (5.4 Hemi MDS, 8-speed)
Eric Stewartson
British Columbia, Canada
Afternoon everyone:
In late November, I purchased a new-to-me RAM 2017 1500 Limited with 38,000 Kms/ 24,000 miles on it. Just after I picked it up, I took the truck to a local RAM dealer for an oil change and inspection service. The inspection came back 98% clean (see below).
At the time, though, I noticed a low-level vibration in the vehicle with the engine running and at a stop (e.g. in Park (with parking brake or main brake applied) or in Drive with the brakes applied). I took the vehicle back to the dealer and asked about this as I didn't think any vibration should be occurring. The Service rep said, "Yeah, nothing to worry about ... it's normal." However, I've spoken to a few other drivers who have the same drive-train and they've said "No, I've had no problem like that." Their vehicles were newer or slightly older.
And, as a matter of detail, the vibration is a bit rougher when the engine is cold vs. warm, yet it generally persists. Sometimes there is no vibration at all (truck is warm, in Drive and at stop) but that's rare. Apart from this, the engine runs smoothly and the RAM "purrs."
Has anyone experienced or is currently experiencing this issue, or am I "barking up a tree?" If this problem is occurring, any idea as to cause and likely remedy? In a few weeks time I'll take the RAM to another dealer for a "second opinion." (I don't think the Service rep I first dealt with was really interested in helping me ... he failed to provide a print-out of the Inspection report and did not tell me the Cabin Air Filter needed changing - even though the Inspection results called it out!)
Thanks in advance for your comments and suggestions.
Cheers and welcome to 2020!
Eric S.
McBroom
Denison Tx
Hemi 6.4L
Check for a loose motor mount bolt or a broken mount. Check the transmission mount as well.
Its fairly easy to check the mounts if your slightly mechanically inclined.
No disrespect intended!
Blue Mule
HEMI19
[QUOTE="Eric Stewartson, post: 2185180
Hello,
I’m having the same issues with my 2019 Ram 1500 Classic 5.7 Hemi, exactly as you described, have you had any success repairing this issue?
PoMansRam
East Aurora NY
My 2019 classic with a hemi has a tiny bit of a shake to it at hot idle as well. I just figured it's all those ponies under the hood waiting for action.
My 2017 with a pentastar you almost had to look at the tach to verify it was idling.
HEMI19
Deleted
HEMI19
Does it shake after it idles down cold too? I’ve noticed in reverse it tends to like to buck slightly as well until I give it gas not so much if at all when it’s warmed up but it’ll still shake in idle.
PoMansRam
East Aurora NY
I don't notice any shakes or vibs on cold startup or during warmup on my 2019 classic.
46RamMan
U.S. Navy Veteran
Missouri
My 2018 is smoooth as buttter all the time... 2018 1500 4 whl drive 5.7 with 8 speed trans and I have 9500 miles on it now. Don't get out much :bawl::driver:
Gregf
