A/C condensation draining into cabin - RESOLVED
Stevewhitts
Maryland
2008 Ram 2500 5.7L
Just noticed water on the floor after running AC in the last heatwave so I assume the condensation drain is clogged. Looks like drain tube is on the firewall side of the Air Inlet Housing and removing that looks like a very big deal. Anyone know where the drain line is under the truck? I was hoping that hitting it with some shop air might blow out the plug and avoid having to tear the dash apart to get to the drain line from inside.
jws123
nj
The drain comes out the firewall on the passenger side stright out of the box blow it out with air it looks like a little grommet
70Cuda70
Los Gats, CA
Cummins Deisel
Same problem. Do you have to remove the splash guard to get to it? I must be blind. Photo? Much appreciated...
2018 Ram 2500, 6.7 Diesel
