A/C problems 2017 Ram 3500
Patrick Venson
2017 & 2011
6.7 Cummins and 4.7
Neither My A/C or heat is not recognizing my touch on the screen nor is it on the knob when I turn it.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
which Ram are you referring to ?
Have you checked the fuse box, by trying to press in the fuses
they tend to work themselves out every once in a while
Then use a tester to check your fuses
P
Patrick Venson
2017 & 2011
6.7 Cummins and 4.7
2017 Ram 3500 6.7 lonestar. I did check all the fuses all were good and press them back in. going to get the at tester though.
