A quick question , want to Upgrade stock speakers on 2104 Ram 1500 Sport.
OrionR5
Toronto, Canada
2019 Ram 1500 Sport
A quick question , want to upgrade stock speakers on 2104 Ram 1500 Sport.
What is the difference between KS and CS Kicker Speakers. For now I'm going to run them on the stock Alpine system.
What do you recommend for the front doors. 6x9's or 6 1/2''. I know the back doors will take a 6x9 without any issues. The Kicker 40CS6934 will just bolt in.
I was looking at Kicker 40CS654 or was wondering if the 40CS6934 which is the same 6x9 that Im putting in the rear can be used for the front.
Regarding the dash speakers. It says Kicker 40CS354 will fit the Centre and Corners but the Kicker 41KSC354 will only fit the corners. Has anyone fit these in the centre dash. They are also higher power handling compared to the 40CS354. 2-50 watts compared to 2-30 watts.
Any suggestions or recommendations to which way to go. Im going to pick up a pair of 6x9's today for the rear- Kicker 40CS6934. Will hold off on the other speakers till I get some input.
Thanks.
MoreOvalteenPlz
Stillwater, OK
The max speaker depth for the front doors is about 2 7/8" which is really rare to find in a 6x9. A lot of guys just run 6.5's for this reason because most have this mounting depth or smaller. I have run Alpine SPR69's in my front for two years now and absolutely love them. As far as the dash goes, I have Kicker KS35's in the corners (no center because no Alpine but I would assume the hole is the same size as the corners). I've seen guys on here mention a mopar kit that comes with 3 Kicker 3.5's for an upgrade to the Alpine system.
OrionR5
OrionR5
Toronto, Canada
2019 Ram 1500 Sport
Thanks MoreOvalteenPlz,
Thats good info. I will look into some 6.5'' speakers. Mopars kit for the three 3.5'' dash speakers will be great. Eliminating the need to buy two sets of speakers.
Thanks for your respond.
Cheers!!!
