? about ball joint seperation
Highwayflyer
2012 express
Gonna do my front springs but not sure whats the best way to get the top ball joint outa the spindle. use a seperator tool and risk tearing up the boot or just wack the control arm with a big old hammer. any ideas will be used.
bigtigga84
dela....where?
When i put my bilsteins in we used a mini sledge and a bar to knock it lose. just gotta be careful doin it that way if you have cv joints cuz if it drops too far they will separate and its a ***** getting em back together.
Pushrod91
Ramona Ca.
Just wack the upper control arm where the ball joint goes thru. That's how I do it. Always works.
Sent from my DROID RAZR using Tapatalk
H
Highwayflyer
2012 express
Ok I ll be wacking away. hummm that dont sound to good huh
Pushrod91
Ramona Ca.
Pics of said whacking. LOL
robby5323
East Texas
2014 Single Cab
Loosen the nut on the top ball joint. Leave the nut threaded on at the bottom a few threads. Take a sledge and hit the spindle. It should pop loose. You can also tap the bottom of the bolt a few times as well to get it to pop....
Reo Cook
Houston
5.7L HEMI
That's what I did and it worked like a charm
