Abs and traction help
Joe Adams
Owensboro, ky
Tried to clear abs fault, it cleared then in a instant came right back on. I do need to replace both batteries but as it is I can't use my cruise control. Any help greatly appreciated. Thank you
Elevated 2013
Huntley, IL
It’s probably a wheel speed sensor. Check the wires and connectors at each wheel and make sure nothing is broken or disconnected. Also check the brake fluid level. It might be low. Before you just fill it, if your brake pads are really warm that will cause the brake fluid level to be low.
GordDavey
Toronto, Ontario
Also, you must go for a small drive before the ABS light will go out, depending on the issue that caused it to come on.
RamCares
n/a
n/a
Hi @Joe Adams - If you are not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your Ram dealer, please do not hesitate to follow up with us via private message. We would be more than happy to get you set up with a specialist for an additional layer of support for the dealer process.
Mark
RamCares
J
Joe Adams
Owensboro, ky
Yes I will. I would rather do it myself I have obdlink mx+ and alfaobd it resets and in a few seconds the abs and traction control lights back on. Does anyone know of a good obd2 for 6.7 ram diesel that would reset and stay reset. Thank you
Elevated 2013
Huntley, IL
Joe, if the light resets and comes back on immediately that means the issue is still happening. There’s no scanner that could turn that off permanently.
Roman217
Metro Detroit, MI
What faults are being reported by ABS module? Pull the DTCs using AlfaOBD. That will give you pretty good idea on what is causing the ABS light.
