ABS and TRANS Issue
kigityk
The other day I noticed that my ABS is activated when applying very minimal braking power. Obviously an issue. Then I noticed that my trans was "slipping", but not in a conventional way, it appears to be bouncing from one gear to another when driving at steady speeds. The problem is intermittent. Today on my way to work, everything was running fine. Then I hit a large pothole and the ABS and trans issue started again. Could I be dealing with a singular issue that is affecting both issues, or is this coincidental? Has anyone heard of a wheel speed sensor affecting the trans?
Thanks!
RamCares
n/a
n/a
Thanks!
Hi kigityk,
We understand why this may be concerning. We suggest having your dealer inspect this concern if you have not done so already. We are also available via private message if you would like any additional assistance during that process.
Lydia
Ram Social Care Specialist
