abs & Brake light new?
MoparMagic'00
Arkansas
5.2 Magnum
ok guys this has been thrown around for sometime now and i have something to ask and add.. my 00 1500 4x4 with only rear abs has the brake light and abs light on.. I've replaced both the sensor on trans and rear end and no avail.. I really can't afford the dealer ship cost of seeing what is wrong i just want to know if anyone else has had same issue after replacing sensors and how to test the module.. also if the module is the same from a 2000 rango with only rear abs as well.. also is there a write up on replacing this module? Merc and DD I expect yall to see this and comment SOMETHING lol thanks in advance
rowdyram
magnum 5.9
Usually having a red brake light too indicates a hydraulic failure. Does the pedal feel normal? Fluid level?
jwheeler
Washington
Have the abs codes pulled. Without knowing the codes, people will just be guessing.
MoparMagic'00
MoparMagic'00
Arkansas
5.2 Magnum
I was afraid of that lol fluid level is good and pedal feels alright
Merc225hp
NA
truck
gas
As posted pull the codes. Me I would start by bleeding the brake system.
MoparMagic'00
MoparMagic'00
Arkansas
5.2 Magnum
would it still need bled if nothing is leaking and decent pedal?
Merc225hp
NA
truck
gas
I could be as simple as just doing that. Have a look at the combo valve and the proportioning valve and see if any of the tell tails are popped out. Check the elec plugs that go on these parts. Check the parking brake light switch make sure its working right.
rowdyram
magnum 5.9
I'm not sure about newer 2nd gens but mine is a 96 and will flash abs codes by grounding pin 13 of the dlc
Reticle918
