dapepper9
- Feb 7, 2013
- 5,906
- 2,227
- Location
- Iowa/Nebraska Border
- 2001
- 5.9L V8
When I went to leave work today I noticed a noise coming from the engine bay. Thought it might be the cold so I drove easy going home and when turned down the radio to park it sounded the same but more pronounced. It's kind of a dry seer seer seer seer seer sound. Sounds like its coming from the ac compressor. Sounds like it may be from the inside (in which case I would need a new compressor) but might be the bearing. Not sure. Tomorrow afternoon I'm going to cut off the old belt and put a new one on but before I put it on I'll play with the compressor a little bit.
Could this happen from having an empty ac system? When I replaced my condenser after the accident I just cracked the line and let all the gas escape. This is my main question about this. If the compressor is what's bad, how much do you think it would cost me to have someone vacuum and fill the ac system?
Hopefully its the bearing but if its not and is in fact the compressor, this shouldn't be too difficult right? Don't need to worry about freon in the system or pressure as I took care of that already lol.
