Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
AC drain line size
Discussion in 'Tech Info' started by Limeybastard, Jan 13, 2016.
  1. Limeybastard
    Limeybastard Senior Member
    1,861
    442
    Jul 25, 2015
    Shady Hills, Rednecksville Boro, Florida.
    Ram Year:
    Engine:
  2. Limeybastard
    1,861
    442
    Jul 25, 2015
    Ram Year:
    Engine:
    Incase anyone wants to do this mod . The 5/8 size was a smudge too small , I believe I will need a 3/4 .
    Sent from my SM-N910T using Tapatalk
  3. Limeybastard
    1,861
    442
    Jul 25, 2015
    Ram Year:
    Engine:
    Ignore my last message. It worked after would you believe it, using lube. No I didn't waste KY jelly. Used some oil and it slipped over drain pipe beautifully.
    Pipe is 4 inches out then 18 straight down. No more wetness all over the frame to cab mount which I noticed causing rust in area where it mates flush with body.
Share This Page
