AC Inverter Harness?
kad
Hudson Valley, NY
5.7L HEMI
Hi guys,
I don't see it listed, but I think this one uses most of the same connectors as the power seat harnesses, so I thought I'd ask. Is a harness for going from the inverter under the passenger seat to the IP3 connector in the kick panel available? I realize the IP3 end would be wires with pins attached and need to be pinned into the IP3 connector and there would still need to be a power wire run from the PDC.
-K
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
@DeereGuy would know since he's made a few. Note sure he's going to make any more going forward for awhile.
M² Mods.
DeereGuy
Preferred Vendor
Pittsburgh, PA
Hi guys,
-K
I have built a few before. I normally run from the connector under the passenger's seat right to the inverter plug bypassing the IP3. You will also either need to run a wire to the BCM or find a power on ignition trigger as well as the power from the PDC. I have all of the parts to build one, but right now I honestly don't know when I could get to it.
kad
kad
Hudson Valley, NY
5.7L HEMI
I'm not in any rush, I was just curious. I've got the parts to build one that goes to the IP3 lined up (Mouser for the inverter end, a user here for the IP3 pins). The concept of going direct to the connector in the dash appeals, but I haven't found the part # for the connector on that end or the pin style to re-pin it. I'm also not sure exactly how a couple of the pins work yet. The 3 AC lines and the power/ground for the inverter are simple, but I haven't figured out the relationship between the following:
1> Inverter Switch Signal (BCM pin 35)
2> Inverter Switch Signal (Dash connector Pin 4)
3> Inverter Status Driver Indicator (Inverter plug pin 7)
4> Inverter Switch Signal (IP Pin 30)
3 & 4 appear to be connected to each other at the IP, but I'm not sure where #4 goes from the IP connector body side and where #1 & #2 end up.
Edit: Just found the relevant connector and wiring diagrams in the schematics archive. I need to sit down and cross reference them, but I think I may see how things go.
-K
