I have seen my oil temps read up to 250F on occasion pulling a heavy load up a steep grade. I'm concerned, but not too worried. I have my truck set to monitor coolant, oil, and transmission temps with physical numbers and bar readout. The bar read out at 240+ is only showing slightly above mid temps on the scale. Once over the hill or steep grade, the temps drop down to normal. Pulling our trailer, the oil temps run 220-230 which is only 15-25 degrees above normal temps without towing. I'll be switching to Mobil 1 tonight to see if it helps this weekend camping. My other thought was to change the thermostat to a 180 degree. This should drop the oil temps in the process. Any thoughts
Paul
