Add On Oil Pressure Guage
StoneDude76
West Chester,PA
Looking to add a oil pressure gauge and keep the factory pressure sensor. Is there a way to run both?
Sent from my VS988 using Tapatalk
Cobble up a "Tee" that screws into the hole where the factory sender is,and will let you use both the factory sender plus tie an oil line in for a stand alone gauge if it's a mechanical gauge,or screw a sender in if it's an electrical gauge.
Fatboy1989
