Adding a level kit to 6" lift kit
abronstrup21
Ok I know I am not the first to ask this question because I have read a ton of blogs about it already but I need answers specific to my set-up. I currently have the Pro Comp Stage II 6" lift. I've adjusted the front up about 1" using the coilovers so the front is almost level with the back. I currently am running 22x12 -44 Fuel wheels with 35" tires. Its time for new tread so I want to go with 24x12's -44 offset on 37" Toyo's. My question is this, without doing a body lift, can I add a 2.5-3" level which would be 2.5-3" up front and a 2" spacer in back and clear the 24's on 37's? If so, what brand should I use?? Other suggestions are welcomed as well. Thanks
Thatdude596
buckeyes state
2009 ram big horn
What gears are you planning on running? Our local shop won't stack the lifts. They said if so in will void the warranty on the pro comp. it also puts the cvs at a bad angle which can cause front end issues
A
abronstrup21
Currently running stock gears. What I don't understand is this, if the stage I lift uses a 6" spacer on stock shocks, why cant I add a 2.5" spacer on the coilovers? I wouldn't be stacking spacers on spacers so why the issue? Wouldn't this be basically like leveling a truck that sits 6" higher that a normal truck?
KAKA
