adding camera where can i pick up 12 volts
donmack
2008 dodge ram slt, im adding a backup camera and need to find 12 volts under the dash when key is on.
freddyx844
North Yorks. UK
Hemi 5.7 on LPG
You could just pick it off the back of the stereo switched live
Bkhsvt
Chicago IL
radio wont have a switched on that year. One of the cig lighters should
Andy
3.7 L
Cig lighter or ignition should do it
baum
savage, mn
2015 Laramie
why not just grab your reverse light so when you in reverse its on? then you dont need to run the wire all the length of the truck
soldiercowboy
Killeen Texas
Hemi 6.4l 4x4 Tradesman crew cab
I have a 2014 tradesman 2500 4x4 and wondering if you know what wire it is that turns on the back up light for the license plate mounted backup camera I got. I git a wired one so no interference so I have to run the rca cable to the monitor anyway and need a power source for both the camera and the monitor. If you have any sujestions would be great.
baum
savage, mn
2015 Laramie
i dont know off hand. but its right at the 7pin trailer harness. reverse light, and ground.
search the forum here there has been a link posted many times (i cant find it right now) where you put in your vin and it will give you all the wire colors and pin/harness locations of the truck. thats what i used for mine.
alphaprojects
