Adjust the LED headlights?
firemedic10584
Central Fl
Anyone know how to adjust the new LED headlights? I'll be putting a leveling kit on my truck tomorrow and will need to aim the headlights back down some. Looking where the normal adjustment bolt is, I don't see the opening anywhere. Any ideas?
1500ram12
5.9L Cummins
What headlights do you have
2018 2500 6.4L
F
firemedic10584
Central Fl
The LED version on the new 2019s. The lower end model I guess, not the kind the comes on the limited.
1500ram12
5.9L Cummins
Ah OK. I have no idea
2018 2500 6.4L
Glenn54
Deep East Texas
Pretty sure I read that you have to take it to the dealer for headlight adjustment. But, I'm old and my memory isn't great.
troutspinner
Gilbertsville, Pa
2019 Big Horn Crew Cab
I don't have a pic but look above where the headlight sits. You'll see a hole you can put a Philips head through and adjust to your needs.
Adam vera
SC
This should help.
  • 08 - Electrical - 8L Lamps and Lighting - Lamps and Lighting, Exterior - Standard Procedure - ...pdf
glsander
