adjustment help please!
azguy123
3.7 v6
is there anyway to adjust the lower control? im having camber issues
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Lower control arm?? It's adjusted by the arm to frame bolts, but you don't wanna mess with that without alignment.
A
azguy123
3.7 v6
well my issues is i put a 3" lift on and i moved my upper control arm in as far as it goes but i still have a camber issue. but my lift did not come with a new cross member which i think is my problem
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Who's lift made by? I haven't heard of a lift without the added cross member.
A
azguy123
3.7 v6
rough country. it came with 4 shocks the two springs and rear blocks and U bolts. that's it. nothing else.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
You put it on yourself, did you get it aligned after install? When you lift the front you always have to do an alignment.
A
azguy123
3.7 v6
yes i went in and they said its the best it can get. there was no adjusting they could do. wouldn't even tell me how off it was. they guy said i need a lower camber caster kit but my control arm has no adjustments anyway.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Like I said, to adjust it you have to crank on the lower control arm bolts as they pivot. You take is to a 4wd outfitter and have them do it, that's where I go because I don't trust other shops anymore. Them not even telling you how off it was and there was nothing they could do leads me to believe that they, in fact, did not do an alignment and jipped you outa some green.
A
azguy123
3.7 v6
its a 2wd is there adjustment on those blots because i didnt see anything.
i wasnt charged for the alignment lol thank god. but yeah i have went to a 4x4 shop they said nothing can be done. i was thinking of purchasing new upper control arms again where i can remove the ball joint and replace it with a adjustable one.
geneseedennis
