Advice on cold air
Brad3030
2014 Dodge Ram big horn
Anyone know of a good cold airintake on a 5.7 hemi ?
sbarron
Wasilla, Alaska
one of the best CAI is the OEM filter setup. Snorkels cold air in and is shielded from the hot engine bay air. Save yourself a couple hundred dollars; maybe put in a K&N filter if you want a little more flow.
d250
Connecticut
5.2 318 v8/5.9l 12v Cummins
If you want a nice high flow performance air intake you need to get ingen twin intake it's the best and for off road use only.
Pull Ya
Cedar Creek, Tx
Brad
If you put this in the 4th gen section under Engines and Performance you might get more information.
Jay
jlafollette07
I'm running s&b [emoji106]
Tray Burge
On the porch
Vararam Air Grabber
Rampitt
i'm running the airaid with the stock airbox with an airaid filter. works great.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
An S&B or AEM drop in filter will give you the same gains as any full aftermarket unit will. If you want to dress up the engine bay a bit then you can go to a full unit but there isn't any performance gain to it. In my opinion, S&B's CAI or a Vararam are the only ones worth swapping too from stock. Anything else is actually less of a CAI than the stock setup.
Also, stay away from K&N filters on a daily driver. While they flow great they are actually terrible at filtering air.
RR7_905RAM
Southern Ontario
2018 Sport
I absolutely love my mopar intake but unless you can get a deal it's ****** expensive so save your money.
If I did it again I would still go mopar but S&B would be on the short list!
Plus I think it's purty! :)
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Talk to Matt at Moe's Performance (preferred vendor link --->).
Vararam is semi-forced air, looks cool and gives best HP gain, for those who do not have to worry about snow and high water.
S&B is next best on gain, and enclosed so no worry about sucking up the wrong kind of atmosphere. Looks better than stock when installed.
Most of the rest are open top which means no cold air, just annoying throttle noise.
