AEV Procal
R.D.J.
6.4 HEMI
Hello all, just leaving a quick note of positive results with the AEV Procal for the 2018 guys. Im sure it works well on years prior as well, but as you may know, 2018 introduced a Security Gateway Module to the CAN.
Basically I wanted it to correct my speedometer, and of course adjust the TPMS thresholds. It DOES require a visit to someone with a Witech tool, and as I had found out it MUST be Witech 2. (In my case I have an independent contact with Witech 1, but had to visit the dealer to use Witech 2)
It works completely as advertised, and in my case it ended up being a pretty economical solution.
LumberJakl
Calgary, AB
6.7L 4X4
I went for the Procal also instead of purchasing a new PCM and a tuner module. I am extremely pleased with it that I was able to re-calibrate my spedo for my 37's.
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
It worked flawlessly on my 2017 also and have had no problems or glitches since programming.
Blue Streak
Southern Oregon
2017 POWER WAGON & 1979 W150
6.4L HEMI & 440 Wedge
It worked as advertised on mine. I still need to take it to the dealer to lock in the TPMS changes though.
pwjouster
South Florida
AEV procal worked like a charm on my 2018 PW
i have an Autel incoming so i can modify the programming for the TPMS module.
wonder what else i can play with in there.
CapandBeard
Alabama
My Procal is on the way to adjust for the 37s getting installed Monday. Did each of you go to the dealer to bypass the TPMS alert light?
joshhhh
