Adventurebound
ProCal works for the 19+ PW, even the "older" version of it. I spoke with tech support and this might sound crazy but when it calls for the step where you put your foot on the brake you need to barely touch it. I verified that did the trick for me. Works perfect, got my speedo corrected and set my TPMS to 35 and turned off the tire dash light.
One other note, the "green star" connector. It needs to be plugged into the larger block, not the skinny one. It's the wire on the far left of the picture attached.
