AF vs SilverBullet Showdown
AF or Silverbullet
  • AF
    Votes: 22 66.7%
  • Silverbullet
    Votes: 11 33.3%
  • Total voters
    33
truckin151
2013 sport
Everything was put back together right? Timing is right? Rods are all seated? Should have ran it last night and used the little time af had today to trouble shoot things.
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
No mine wasn't near this bad. Mine never actually stalled...just surged like it wanted to stall. The perfect idle for the first 4 min confirms everything was put together right. I'm confident this is just a matter of the pcm not getting along with the cam.
Oefootball_70
OLATHE
Isn't it key cycles that helps?
Turn it on and off a few times maybe?
truckin151
2013 sport
If it was running alright for longer than 4min I would agree with you but the fact that only ran fine for 4min makes me think something other than the pcm isn't quite right
S
Silverbullet08
Persona Non Grata
sam thinks it bc im running open headers with no 02 sensors plugged in. problem is i cant get it to a shop since it wont drive that far....
glass3222
Central PA
can you plug in the front o2 to the bungs on the headers? It might be good enough to get you to the shop
OklaHemi
new age hemi
i dont have open headers but i have no o2 sensors. truck runs fine
S
Silverbullet08
Persona Non Grata
yea i think i can plug the front ones in. it will have to wait till tomorrow. ill have to get a ride back over to my parents house since the truck is there...
S
Silverbullet08
Persona Non Grata
i believe aarons install was good. it ran good then stalled out and the battery was dead. leads me to believe the battery was on its last limb. ill try to figure it out more tomorrow. good thing i live walking distance from my school
blk05hemi
Bovina, TX
Cummins 6.7
Definitly get those front o2s in. Hope you get this figured out Nick.
truckin151
2013 sport
That would do it right there. The frong O2's are what helps the pcm with the fuel trims the rear ones are for the cats. Get them in and reset the pcm and it should be much better.
BTW - I meant that it sounded more like something else was the cause other than the pcm, you guys messed with a lot of stuff so even if he put it all back together right there could be a wire that burnt on the headers or something not plugged in right. Like the front O2s.
It's the front o2's not being plugged in that's the problem. The PCM doesn't know what to do in terms of adding/pulling fuel without those sensors.
AF_Hemi
Better the wrench than the whole truck lol. I agree 100% that will most likely fix the problem. It ran great until the pcn started really taking samples of the air from the o2 sensors. Plug in the fronts and it'll run I guarantee it. Let us know tomorrow.
By the way, as I said before it was great meeting you as well. Had a great time. Be sure to tell Jim thanks again from me also.
S
Silverbullet08
Persona Non Grata
oh btw it was really fun pushing it down my drive way lol. it kept stalling in reverse... then i had to get gas lol
truckin151
2013 sport
Just watch those front O2's, on mine when I installed the the passengerside **** was pointed straight up so the O2 was hitting the heat sheild and would not go in. Had to take a hammer and pound the heat sheild in about the size of a baseball before it would fit right.
truckin151
2013 sport
Also had to trim the **** down about a 1/4" or so too...
