Bperrine
I'm having trouble with my aftermarket back up camera rolling. Is there a better place to get 12v to the camera and the reverse signal than the reverse light?
Several questions:I'm having trouble with my aftermarket back up camera rolling. Is there a better place to get 12v to the camera and the reverse signal than the reverse light?
I got pow and ground from the trailer harnessSeveral questions:
-Make, model and year?
-Have you tried a separate power supply for testing purposes ie, a battery just to see if it is indeed the reverse light circuit?
That's where I would start as it's possible the circuit is driven by pulse width modulation and that can affect the camera, conversely if it continues when tested with a battery source it is likely a bad camera or interference being picked up in wiring..
Reply with results and I'll be glad to help you continue to diagnose it..
Bill
Sent from my ONEPLUS A6013 using Tapatalk
