Aftermarket brake controller vs OEM and location?
Fishhaggis
Vancouver Island
My dealer does not recommend the OEM brake controller for my 2017 Bighorn as they say it’s way too expensive and suggest an aftermarket brake controller instead. This sound right?
I am long legged and need leg room. Concerned I bash my knees on an aftermarket brake controller if installed under the dash under the steering wheel. Where has anyone installed an aftermarket brake controller not under the dash where your knees go?
Thanks.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Thanks.
Don't tell me, he sells aftermarket brake controllers, too. I did the OEM install on my '16 Sport and was actually cheaper than the P3 I had. Only thing that could raise cost is the BCM programming, but I did it with AlfaOBD and OBDLink MX+ that I already had, so it cost me zip.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
I have had both. My Gen4 truck had the OE brake controller and it didnt work with my one of my fifth wheel trailers well at all. Went with the after market P3, and it worked great.
Central Ohio
2020 Classic
Older thread, Im aware...
My $0.02.... Buy the OEM one off ebay or other site, install it yourself. Takes about 20 minutes. Not hard at all if your truck has the towing package.
It's recommended to do flash the computer so that you can "unlock" the brake controller screen on the dash, and see the brake bias when you make adjustments, but the controller will work just fine without the flash.
I drove mine for a few weeks and did some towing without the flash, so I can confirm that it works. I eventually got the AlphaOBD program and was able to make the flash myself. Had I gone to the dealership it probably would have been an $800-1000 job, but I think I'm at around $300 total which includes buying the AlphaOBD software, the USB to OBD2 cord, and the security bypass harness
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
Hopkins INSIGHT …you can mount the controller / controls / indications wherever you want.
I’ve had this on two different Rams and it works beautifully…. towing utility, Airstream, and 10K Dump trailer. It handled each, Very smart.
