Aftermarket brake controller wiring
mrugg
6.7 cummins
I am in need of the pigtail wire plug that usually comes in the glove box of most trucks to wire up a aftermarket brake controller. Can someone here tell me where to get one? I have already purchased the controller when I realized I didn't have it or I would have ordered it with a pre wired plug for my 2012 ram 2500. Yes I already have the plugs under the dash.
Sent from my SM-G977U using Tapatalk
chri5k
USA
Diesel
Try etrailer.com They have a large selection of controllers and the associated harnesses to go from the controller to the plug under the dash.
M
mrugg
6.7 cummins
Thank you I will go there now and look.
indept
South Jersey
Not sure about your truck but the connector on the 1500's is up under the dash where the key / starter button is.
M
mrugg
6.7 cummins
Yes I stated that I have those plugs, I am looking for the one that usually comes with the truck to use a aftermarket brake controller and plug it into one of those
indept
South Jersey
That connector I mentioned is the one that my aftermarket controller plugs into. Mine was tucked up in the dash with foam wrapped around it not plugged into anything.
M
mrugg
6.7 cummins
Thank you for the help guys. I just ended up ordering the already made harness that goes from my new tekonsha p3 brake controller to my truck. No wiring just plug it in.
MarshRam
2014 SLT 4x4, 2012 ST
Just missed you, would have sold you mine.
M
mrugg
6.7 cummins
Ah man! I appreciate it. Yea I was getting a little anxious. I wanted to get it hooked up as soon as possible. I bought a new dump trailer and need it. Thank you very much.
glsander
